Quote: I put another pump on it, and it still has the same issue. I have a Mallory 110 pump I want to put on it. But I can't find a good place to mount it.
have you tried another guage ?
The electric pump needs to be as close to the fuel source as possible , over the rear axle off to one side is a possible place , make sure the rear axle won't hit anything with full suspension compression.
