So I got everything back together on the Fury last night. Ever part of the fuel system is new. From the pick up to the carb. Well only one old part, the fuel pump push rod. I still have the same issue I had before . I can't get more then 3 psi of fuel pressure, and with in a minute, I have nothing. I'm running a e-Brock mech pump. I pulled the pump off and checked the length of the pushrod. It is 3.22" long. I found comp cams sell to different lengths of rods. 3.22 and a 3.242. The pump arm only has .75 of movement. My current push rod does not look wore or damaged. I also pulled the distributor to look at the cam. No signs of wear there either. I have also tried running the car from a gas can. No luck. Any help is appreciated.
