More octane only makes you go slower if you dont need it to prevent detonation. The higher the octane the slower the gas burns.
This is not true.
do your research online before you make a comment here. Race gas need to burn fast not slow. dont confuse anti detonation qualities with slow burn.
An oxygenated gas of higher octane along with richening it up a bit will make more power.
Anyway there are s lot of sites that "teach" about racing gas and its properties. I suggest you start reading.
