Ive got my convertable body ready to paint the jambs and under hood and trunk areas. Just trying to figure out a good plan of attack. I wanna paint with fenders off. should i paint all the way to the outside sheet metal or stay back in aways. what im looking at is painting the windsheild frame, underhood, trunk right up to where the weather stripping glues for trunk seal so when trunk is on all under lid will be painted, door jambs to where with doors on all inside will be painted and leaving just exposed cowl area to be painted on front. Im using base clear if that matters. Any suggestions appriciated.
