Quote: I thought if you ran solid engine mounts you had to have a solid trans mount?
I sure wouldnt... reason why is flex in the car... if you have 2 points solid (now thats a straight line) it can pivot BUT if you have a front plate, mid plate and a solid trans mount, now you have 3 points which doesnt mean its still a straight line, specially when you induce flex... I always use a rubber trans mount and I have never broke a tail shaft.... some guys use the solid trans mount as a engine limiter... I prefer to put a engine limiter on the engine(I happen to use 2 of them)
