There used to be 0.001" UNDERSIZED bearings available as the OP said. They could still be available. There are also 0.001" oversized bearings for when you want to have a bigger clearance.
Sounds doable to me, although I'd say that extra 0.0009" won't kill you if you use standard sized bearings.
R.
You are right - my mind was in reverse. Use them to slightly tighten the clearances..
