I was thinking of these. Are these .001" over or under? It doesn't say.
http://www.competitionproducts.com/Clevi...info/CB527P001/
They will give .001 less clearnce. Used to slightly tighten the clearance.
Take that shaft and have it professionally checked for out of round and taper. Just because it may look good it may not be. It is not that spendy to have the shaft at least polished or turned .010. Then you know where you are and the bearings will be the same price.
