hey there, your measurements are already under min. spec.,but you would not want to buy .001 undersize bearings. that would add .001 clearance to what you already have! however, ideal bearing clearance in performance engines is generally considered as .001 per 1 inch of crankshaft diameter.so, ideally you could have as much as .0026-.0027 and be o.k.
