I have the fuel pressure set at 7 lbs, it was dripping lots of fuel down the carb when the idle was set so high. Tommorrow I will get it going and try getting on the idle screws after i have it idling at about 1000rpms, I still want to add a little more timing as well I had it set low for the initial break-in of this new motor.
