OK...Here is what we are going to do. The lowest rpm chip I could find is 3400. So that will be a start. I will also try to change my driving technique by resting my left arm on the bar with my hand in the 7:00 o'clock position. All of the years leaving off the footbrake I had one hand on the shifter and the other at the 10:00 o'clock position. Thanks for all of the suggestions,guys!!
Need your rear end checked out? Contact Grizzly!!
