On launch if you are not lined up straight or if you are a little out of the groove it will do that. It looked like you were lined up right,that's just something to check next time at the track. If I were were you before going back to the track I would switch the rear tires and see if it starts pulling to the right.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
