Depends on how pliable the right stuff is , the cover needs to MOVE .
well i ordered a gasket from the dealer...Just worried that it will leak since even with the right stuff i had the old synchromesh leaking in one spot.
Im assuming its possible to get the cover back on the forks with the transmission in the car, just a very hard and annoying procedure I imagine?
