Quote: .Speaking of drain tubes let's touch on this subject...I hated the way those tubes just drain into the quarter panel/cowl with a factory sunroof..
Colin,....I agree 100%, big mistake on the factory's behalf just letting the tubes terminate inside the unibody,....every install I ever did, I increased the tube size as much as possible, and allowed the tube to exit the chassis in some fashion, very much like you have.....
