Great thread !
...Hey Mike...Speaking of drain tubes let's touch on this subject...I hated the way those tubes just drain into the quarter panel/cowl with a factory sunroof...I ended up daylighting each tube...I drilled holes in the outer wheelhouse {in front of the rear tire} for the back drains...Then after much contemplation I drilled holes through the cowl's sheetmetal near the lower door hinges threaded reinforcing plates...I just could'nt bring myself to let the water run into the car after the resto....
