472 hemi world block over heating problem #2623049
02/18/19 08:34 PM
02/18/19 08:34 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
ok im working on a 472 hemi, im not sure what heads just yet, i have not removed VC yet.it is a world block, and it runs hot 260-280+.
new water pump, new big aluminum rad, 2 elec. fans on full time.
the customer purchased the car sight unseen , and it has ran hot from the beginning, pushed in a corner for 2 years.. and he know nothing about the details of the engine. its got major blow bye now, im assuming rings are shot, i will comp. test and leak down..soon. is there anything to look at as far as the block and head combination?
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623072
02/18/19 09:58 PM
02/18/19 09:58 PM
Sweden
MikeN Offline
MikeN  Offline
Sweden
Some World blocks had a casting failure with no or limited waterflow between pump and cylinders.
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623085
02/18/19 10:28 PM
02/18/19 10:28 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Sooo much could be off,fuel,timing,dirt in carb...
GOTBOOST!New improved with Victor heads.
http://www.enginelabs.com/mopar-big-bloc...t-of-necessity/
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623093
02/18/19 10:46 PM
02/18/19 10:46 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
does the block have any fill in it?
Re: 472 hemi world block over heating problem [Re: MikeN] #2623112
02/18/19 11:21 PM
02/18/19 11:21 PM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
are there any certain numbers or markings on the bad blocks? how can i tell?
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623140
02/19/19 12:14 AM
02/19/19 12:14 AM
Sweden
MikeN Offline
MikeN  Offline
Sweden
I dont have access to a fullscreen computer just now so posting a link gets difficult but if you look for an old post I made July 9 2016 you will see a thread (426 Hemi gasket backwards?) how two other members handled this problem.
The problem exists on some of the the World "street iron block".
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623149
02/19/19 12:39 AM
02/19/19 12:39 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'm having a hard time accepting the car ran @ 260*+ work
If it ran well and the gauge was 260,,,it's defective.Flush the fuel system and see if you can start the car and start the diagnostics up
Oh,check the oil to see that it looks OK and does NOT smell like gas!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 472 hemi world block over heating problem [Re: MikeN] #2623151
02/19/19 12:40 AM
02/19/19 12:40 AM
cincinnati ohio
mcat4321 Offline OP
mcat4321  Offline OP
cincinnati ohio
found it! thanks... lots of great info
i will for sure be checking the part number
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623222
02/19/19 06:55 AM
02/19/19 06:55 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
My 572 world block had casting flash in the upper holes for the water pump, had to use a hole saw to clean them up...its easy to spot if its bad. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623297
02/19/19 01:46 PM
02/19/19 01:46 PM
fast68plymouth Offline
That’s interesting info on those plugged passages in the world blocks........ and that it’s not a “one off” situation.
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623306
02/19/19 02:14 PM
02/19/19 02:14 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
check the head gaskets - pretty common problem of the water holes to the heads being blocked when using the wrong head gasket
Re: 472 hemi world block over heating problem [Re: mcat4321] #2623313
02/19/19 02:27 PM
02/19/19 02:27 PM
Maryland
Dads426 Offline
Dads426  Offline
Maryland
I would check cylinder head temp with an IR gun. We had fill in one block that blocked the rear two cylinders and the passenger head ran significantly hotter than the drivers side.
2012 422 Allstars NSS Champion
2013 422 Allstars NSS Champion
2014 422 Allstars NSS Champion
Re: 472 hemi world block over heating problem [Re: Dads426] #2623413
02/19/19 07:14 PM
02/19/19 07:14 PM
dogdays Offline
dogdays  Offline
Run it on alcohol or E85 if the other suggestions don't get you anywhere.
R.
