472 hemi world block over heating problem
#2623049
02/18/19 08:34 PM
02/18/19 08:34 PM
Posts: 3,101 cincinnati ohio
mcat4321
cincinnati ohio
ok im working on a 472 hemi, im not sure what heads just yet, i have not removed VC yet.it is a world block, and it runs hot 260-280+. new water pump, new big aluminum rad, 2 elec. fans on full time. the customer purchased the car sight unseen , and it has ran hot from the beginning, pushed in a corner for 2 years.. and he know nothing about the details of the engine. its got major blow bye now, im assuming rings are shot, i will comp. test and leak down..soon. is there anything to look at as far as the block and head combination?
Re: 472 hemi world block over heating problem
[Re: MikeN]
#2623112
02/18/19 11:21 PM
02/18/19 11:21 PM
mcat4321
cincinnati ohio
Some World blocks had a casting failure with no or limited waterflow between pump and cylinders. are there any certain numbers or markings on the bad blocks? how can i tell?
[Re: mcat4321]
#2623149
02/19/19 12:39 AM
02/19/19 12:39 AM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I'm having a hard time accepting the car ran @ 260*+ If it ran well and the gauge was 260,,,it's defective.Flush the fuel system and see if you can start the car and start the diagnostics Oh,check the oil to see that it looks OK and does NOT smell like gas!
[Re: mcat4321]
#2623222
02/19/19 06:55 AM
02/19/19 06:55 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
My 572 world block had casting flash in the upper holes for the water pump, had to use a hole saw to clean them up...its easy to spot if its bad. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: mcat4321]
#2623297
02/19/19 01:46 PM
02/19/19 01:46 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
That’s interesting info on those plugged passages in the world blocks........ and that it’s not a “one off” situation.
[Re: mcat4321]
#2623313
02/19/19 02:27 PM
02/19/19 02:27 PM
Posts: 1,443 Maryland
Dads426
Maryland
I would check cylinder head temp with an IR gun. We had fill in one block that blocked the rear two cylinders and the passenger head ran significantly hotter than the drivers side.
2012 422 Allstars NSS Champion 2013 422 Allstars NSS Champion 2014 422 Allstars NSS Champion
