Green bearing O ring seal
#2564292
10/15/18 10:36 AM
10/15/18 10:36 AM
Posts: 2,410 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I know this may be a reach but does any one happen to know the part number of the O ring that fits on the 8 3/4 green bearings? I had a set of axles sitting on the shelf for years and discovered one of the bearings missing its O ring yesterday just as I was about to slide it in the housing...
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
Re: Green bearing O ring seal
[Re: jbc426]
#2564389
10/15/18 01:48 PM
10/15/18 01:48 PM
RapidusMaximus
Weatherford, Texas
Yep...thats probably what I'm about to do, I know he's a busy guy was trying to keep from bugging him but looks like I'm going to have to...
[Re: moparx]
#2564821
10/16/18 01:52 PM
10/16/18 01:52 PM
RapidusMaximus
Weatherford, Texas
Will do, I have a call in to Dr. Diff...
[Re: RapidusMaximus]
#2564885
10/16/18 03:31 PM
10/16/18 03:31 PM
RapidusMaximus
Weatherford, Texas
And the verdict is...take the axle to the parts store and find one that fits the groove and OD of the bearing but doesn't stick up too far (too thick). The bearings of course come with the O ring installed so anytime he has an issue he matches one up from the parts store. Kudos to Cass for taking time out to help me out
[Re: moparx]
#2565328
10/17/18 01:07 PM
10/17/18 01:07 PM
RapidusMaximus
Weatherford, Texas
My assumption is the only way to get the pn would be to call the bearing manufacturer and see if it would be possible to convince the right person to pull a blueprint and then give up the pn of the O ring...having worked at big companies most of my life I think that might be a really frustrating phone call
#2565469
10/17/18 05:36 PM
10/17/18 05:36 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
If the O ring is missing, you can measure the width of the groove; that, along with the ID of the housing bore (2.875") gives you a place to start.
[Re: jb500]
#2567402
10/21/18 06:01 PM
10/21/18 06:01 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Should be no more than $.50 depending on store mins. & would have been done days ago if you would have just gone and got one.
