Green bearing O ring seal #2564292
10/15/18 10:36 AM
10/15/18 10:36 AM
Weatherford, Texas
RapidusMaximus Offline OP
Weatherford, Texas
I know this may be a reach but does any one happen to know the part number of the O ring that fits on the 8 3/4 green bearings? I had a set of axles sitting on the shelf for years and discovered one of the bearings missing its O ring yesterday just as I was about to slide it in the housing... rant
1968 Plymouth GTX
1974 Dodge P/U Long Bed Stepside 318
2019 Ram 2500 6.4, auto, 4WD
Re: Green bearing O ring seal [Re: RapidusMaximus] #2564386
10/15/18 01:43 PM
10/15/18 01:43 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Call and ask Dr Diff.
Re: Green bearing O ring seal [Re: jbc426] #2564389
10/15/18 01:48 PM
10/15/18 01:48 PM
Weatherford, Texas
Weatherford, Texas
Yep...thats probably what I'm about to do, I know he's a busy guy was trying to keep from bugging him but looks like I'm going to have to...
1968 Plymouth GTX
Re: Green bearing O ring seal [Re: RapidusMaximus] #2564801
10/16/18 01:03 PM
10/16/18 01:03 PM
moparx Offline
moparx  Offline
please report back what you find out.
beer
Re: Green bearing O ring seal [Re: moparx] #2564821
10/16/18 01:52 PM
10/16/18 01:52 PM
Weatherford, Texas
Weatherford, Texas
Will do, I have a call in to Dr. Diff...
1968 Plymouth GTX
Re: Green bearing O ring seal [Re: RapidusMaximus] #2564885
10/16/18 03:31 PM
10/16/18 03:31 PM
Weatherford, Texas
Weatherford, Texas
And the verdict is...take the axle to the parts store and find one that fits the groove and OD of the bearing but doesn't stick up too far (too thick). The bearings of course come with the O ring installed so anytime he has an issue he matches one up from the parts store. Kudos to Cass for taking time out to help me out up
1968 Plymouth GTX
Re: Green bearing O ring seal [Re: RapidusMaximus] #2565310
10/17/18 12:25 PM
10/17/18 12:25 PM
moparx Offline
moparx  Offline
o-rings are sized according to od, id, and thickness. there has to be some information on the correct size, other than "take it to the parts store and match something up that doesn't stick up too far". confused
beer
Re: Green bearing O ring seal [Re: moparx] #2565328
10/17/18 01:07 PM
10/17/18 01:07 PM
Weatherford, Texas
Weatherford, Texas
My assumption is the only way to get the pn would be to call the bearing manufacturer and see if it would be possible to convince the right person to pull a blueprint and then give up the pn of the O ring...having worked at big companies most of my life I think that might be a really frustrating phone call twocents
1968 Plymouth GTX
Re: Green bearing O ring seal [Re: RapidusMaximus] #2565469
10/17/18 05:36 PM
10/17/18 05:36 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If the O ring is missing, you can measure the width of the groove; that, along with the ID of the housing bore (2.875") gives you a place to start.
Re: Green bearing O ring seal [Re: RapidusMaximus] #2566932
10/20/18 02:55 PM
10/20/18 02:55 PM
TN Hoosier
jb500 Online content
jb500  Online Content
TN Hoosier
It may be a -147 (.103) or -231 (.139) o-ring depending on the thickness of the seal. Mic the seal you have and verify the cross section. Go to a Parker store or similar Hyd shop with the seal or axle and have them match up/verify the size you need. Should be no more than $.50 depending on store mins.
The Parker O-ring catalog online has a bunch of info you can go over if needed. Catalog # ORD 5700.
Re: Green bearing O ring seal [Re: jb500] #2567402
10/21/18 06:01 PM
10/21/18 06:01 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
& would have been done days ago if you would have just gone and got one.
shruggy
I have mechanical Aptitude.
I can screw up anything.
Re: Green bearing O ring seal [Re: RapidusMaximus] #2567404
10/21/18 06:16 PM
10/21/18 06:16 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
This is not rocket science.
Take the bearing to a parts store and trial fit 2-3 O-rings from their assortment until you find one that fits. This takes less than 5 minutes.
