Re: Is this a torsion bar LCA issue?
[Re: stumpy]
#2536094
08/14/18 11:48 AM
08/14/18 11:48 AM
Posts: 14,889 up yours
Supercuda
You want the LCA as low as you can get it not high. This You need to pull the LCA down to line up with the T bar hex, not up. You found out why it's not up, see your pic.
[Re: ksat]
#2536330
08/14/18 06:39 PM
08/14/18 06:39 PM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
I take the shock and bump stop off, that will let the lca drop enough to slide bar in easily. Like one said make sure you got them on the right side as marked.
