I got my torsion bars installed today. I had a hard time getting the hex opening of the LCA to line up with the bars, but I was finally able to get them into a position so the bar could slip in. I did it by raising the LCA with a jack until the hex opening and the bar were lined up.
It says in the FSM to then turn the torsion bar adjusting bolt so that a load is placed on the bar. But right now the adjusting blade is pretty high. I'm thinking something is wrong here. Should I redo everything so that the blade is in a lower position initially?
