Is this a torsion bar LCA issue? #2535936
08/14/18 12:10 AM
08/14/18 12:10 AM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I got my torsion bars installed today. I had a hard time getting the hex opening of the LCA to line up with the bars, but I was finally able to get them into a position so the bar could slip in. I did it by raising the LCA with a jack until the hex opening and the bar were lined up.
It says in the FSM to then turn the torsion bar adjusting bolt so that a load is placed on the bar. But right now the adjusting blade is pretty high. I'm thinking something is wrong here. Should I redo everything so that the blade is in a lower position initially?
Re: Is this a torsion bar LCA issue? [Re: ksat] #2535943
08/14/18 12:17 AM
08/14/18 12:17 AM
BDW Offline
BDW  Offline
Yes, loosen the bolt as much as possible and rotate down to the next hex
Re: Is this a torsion bar LCA issue? [Re: ksat] #2535961
08/14/18 12:49 AM
08/14/18 12:49 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Did you remove the UCA bump stop? This lets everything drop enough to line up with T/bar.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Is this a torsion bar LCA issue? [Re: ksat] #2535986
08/14/18 01:40 AM
08/14/18 01:40 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You want the LCA as low as you can get it not high.
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536041
08/14/18 09:26 AM
08/14/18 09:26 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Make sure you have them installed on the properly marked side. Right and left.
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536042
08/14/18 09:43 AM
08/14/18 09:43 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
Did you have the lower control arms removed? If so the mounting bolts for them should not be tightened until the car is at ride height.
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536064
08/14/18 10:26 AM
08/14/18 10:26 AM
Minn
SportF Offline
SportF  Offline
Minn
I think you must surely have the bar in there off on the hex part by one hex. There is no way that can be right.
Re: Is this a torsion bar LCA issue? [Re: stumpy] #2536094
08/14/18 11:48 AM
08/14/18 11:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
This
You need to pull the LCA down to line up with the T bar hex, not up. You found out why it's not up, see your pic.
Don't be the exception.
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536136
08/14/18 01:13 PM
08/14/18 01:13 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You have your adjusting bolt turned all the way IN. You need it all the way OUT. The bolt should be hanging out the bottom of the LCA and the adjusting blade should be touching the bolt when you install the torsion bars.
Re: Is this a torsion bar LCA issue? [Re: burdar] #2536262
08/14/18 04:55 PM
08/14/18 04:55 PM
USA
K
ksat Offline OP
ksat  Offline OP
K
USA
I'm not at the house right now to take a look at things but I'm sure that I'll have to remove the UCA bump stops to get things lower.
So then I'm going to remove the bar from the LCA, lower the blade as much as possible towards the adjusting bolt, and then reinsert the bar. Once the bar is out of the LCA will the blade easily move down? Or is there something else that needs to be done so the blade is free to move easily?
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536276
08/14/18 05:15 PM
08/14/18 05:15 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
unscrew the adjuster bolt so the ball is flush with the insert, once the torsion bar is pulled out you should be able to move the blade down by hand.
push the arm down as far as it will go, push the blade down as far as it will go, slide the tb into the hex, you might have to move the blade slightly to get it to line up with the tb.
Re: Is this a torsion bar LCA issue? [Re: ksat] #2536330
08/14/18 06:39 PM
08/14/18 06:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I take the shock and bump stop off, that will let the lca drop enough to slide bar in easily. Like one said make sure you got them on the right side as marked.
