Re: Li'l Red Express w/EFI - What Pump Setup??
[Re: GoodysGotaCuda]
#2466598
03/14/18 08:52 PM
03/14/18 08:52 PM
Posts: 5,777 ohio
ruderunner
ohio
87-93 pickups were fi. Not sure if the filler neck swaps but the guage will work correctly. You need the whole tank.
Angry white pureblood male
[Re: ruderunner]
#2467860
03/17/18 08:49 PM
03/17/18 08:49 PM
Posts: 1,093 It's beer:30 somewhere
adventurer
FiTech makes a command module fuel pump that could easily be mounted in the space in front of the passenger side inner fender with some creative bracket fab. It uses the stock tank sending unit and your stock mechanical pump to feed it then ramps up the pressure for the efi. They also show an in tank tight fit application that can be put in the original tank and still have the original sending unit. I personally have not used either but have been looking at fairly close and they both look like good options. Hope that helps.
77 Dodge Adventurer SE 440 2wd SWB 78 Dodge Adventurer SE 440 2wd Utiline 90 Dodge D150 SWB 2wd 318fi 4speed 60 Desoto Adventurer 2dr 67 Dodge Dart Gt Conv. 273 4bbl 04 PT Cruiser GT Turbo 14 Ram R/T "Life's to short to drink cheap beer."
[Re: adventurer]
#2467921
03/17/18 11:55 PM
03/17/18 11:55 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
FiTech makes a command module fuel pump that could easily be mounted in the space in front of the passenger side inner fender with some creative bracket fab. It uses the stock tank sending unit and your stock mechanical pump to feed it then ramps up the pressure for the efi. They also show an in tank tight fit application that can be put in the original tank and still have the original sending unit. I personally have not used either but have been looking at fairly close and they both look like good options. Hope that helps. Thanks. We initially bought the fuel command center but after reading the overwhelming bad reviews from FiTech owners regarding it. We are returning it in favor of some other in take or traditional surge tank option.
