Li'l Red Express w/EFI - What Pump Setup?? #2465524
03/12/18 11:11 PM
03/12/18 11:11 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Father-in-Law is putting a FiTech on his LRE.
Shall we try an inline pump, or is there a good option for an in-tank that allows me to keep the factory sending unit?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Li'l Red Express w/EFI - What Pump Setup?? [Re: GoodysGotaCuda] #2466598
03/14/18 08:52 PM
03/14/18 08:52 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
87-93 pickups were fi. Not sure if the filler neck swaps but the guage will work correctly. You need the whole tank.
Angry white pureblood male
Re: Li'l Red Express w/EFI - What Pump Setup?? [Re: ruderunner] #2467860
03/17/18 08:49 PM
03/17/18 08:49 PM
It's beer:30 somewhere
adventurer Offline
adventurer  Offline
FiTech makes a command module fuel pump that could easily be mounted in the space in front of the passenger side inner fender with some creative bracket fab. It uses the stock tank sending unit and your stock mechanical pump to feed it then ramps up the pressure for the efi. They also show an in tank tight fit application that can be put in the original tank and still have the original sending unit. I personally have not used either but have been looking at fairly close and they both look like good options. Hope that helps.
77 Dodge Adventurer SE 440 2wd SWB
78 Dodge Adventurer SE 440 2wd Utiline
90 Dodge D150 SWB 2wd 318fi 4speed
60 Desoto Adventurer 2dr
67 Dodge Dart Gt Conv. 273 4bbl
04 PT Cruiser GT Turbo
14 Ram R/T
"Life's to short to drink cheap beer."
Re: Li'l Red Express w/EFI - What Pump Setup?? [Re: adventurer] #2467921
03/17/18 11:55 PM
03/17/18 11:55 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks. We initially bought the fuel command center but after reading the overwhelming bad reviews from FiTech owners regarding it. We are returning it in favor of some other in take or traditional surge tank option.
2020 RAM 1500
