Charging Question #999965
05/26/11 12:13 AM
05/26/11 12:13 AM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
strange thing , i have only driven my car about 50miles on the road,
68 dodge coronet-440/727, i have changed the alternator to square back, changed out the voltage reg. to a 70's style, did the madelectric wiring , no amp meter, amp bypass and put a volts meter, i did this about couple of months and maybe driven the car off and on 2 times to the store up the road about 5miles
i cranked up the car tonight, drove 5miles to store , put gas in , drove back home everything was fine, turned off car, got back in the car about 5mins later and pulled in garage, notice only 12volts on meter, i got out got my tester, and the alternator not charging like it should per the tester,
i turn the car off and checked all the connections, cranked the car back up, everything is fine, the volt meter up past 14volts, i cut the car off and cranked about 3 or 4 times no problems,
anybody have an opinion on this, what wld cause this? and now running fine, i am wondering if this is a alternator problem waiting to happen on a long cruise night
Re: Charging Question [Re: cornet684me] #999966
05/26/11 12:44 AM
05/26/11 12:44 AM
Got a loose/intermittent connection somewhere in the field circuit. check the terminals/connections and the brushes etc for (hopefully) something obvious plus check the bulkhead
Re: Charging Question [Re: RapidRobert] #999967
05/26/11 12:52 AM
05/26/11 12:52 AM
Brandon, Ms
Brandon, Ms
hello Robert, so you think something is just working loose?
i just cannot get away from electric with this car! i have always heard mopars are bad about having electric problems and i have had my share with this car
Re: Charging Question [Re: cornet684me] #999968
05/26/11 03:19 AM
05/26/11 03:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Loose connection or bad voltage regulator. I had simular problem and it was the regulator. I opened up the regulator to inspect it and it had a bad solder joint.
Re: Charging Question [Re: cornet684me] #999969
05/27/11 12:44 AM
05/27/11 12:44 AM
Brandon, Ms
Brandon, Ms
Update- battery no good
well, i took the car out for a short drive about 5miles up the road and i stopped and talked with a friend, when i got back in the car, it almost did not crank, the starter dragging, i got back to the house turned off the car, come back to put in the garage, the car when not crank the inside lights all dim, the volts down to almost nothing,
tested the battery, showing bad battery, so i took the battery out of my truck and put in the car, fired right up, all the readings fine
apparently when i had all my voltage reg. problems and the car ran at 16 to 19volts, it must have fried the battery
thanks for the input
Re: Charging Question [Re: cornet684me] #999970
05/27/11 12:46 AM
05/27/11 12:46 AM
Randy your luck has to turn sometime
Re: Charging Question [Re: RapidRobert] #999971
05/27/11 12:53 AM
05/27/11 12:53 AM
Brandon, Ms
Brandon, Ms
i agree Robert, you wld not believe all the attention my car is getting, people cannot believe i did all the work in my garage, it is all worth it , when the 440 is running down the street, i am taking the car to my work about 13miles 1 way tommorrow, to show off to coworkers
wish me luck
Re: Charging Question [Re: cornet684me] #999972
05/27/11 12:55 AM
05/27/11 12:55 AM
Brandon, Ms
Brandon, Ms
it's pretty, but tries my patience almost every weekend
Re: Charging Question [Re: cornet684me] #999973
05/27/11 12:55 AM
05/27/11 12:55 AM
wish me luck
I'm wishing you good luck
