transmission breather relocation #999811
05/25/11 06:53 PM
05/25/11 06:53 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
when relocting a trans breather i know some,including Cope Trans,recommend drilling into the main case web.
is there any problem with just drilling and fitting a breather/pipe fitting in the extension housing ?
i am thinking of putting a 90 degree 1/8NPT fitting here and running a 3/8" breather hose up to the engine bay
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: transmission breather relocation [Re: tex013] #999812
05/25/11 09:19 PM
05/25/11 09:19 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Tex
I originally had mine there and it all over ,,finally put it where it belonged and not even a dribble since.
Re: transmission breather relocation [Re: dartman366] #999813
05/25/11 09:44 PM
05/25/11 09:44 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
I have mine there.
I originaly had a -4 line going up to a diff breather and it would still spew fluid out.
I now have a -6 line going up to a Jr dragster catch can mounted on the fire wall.
Re: transmission breather relocation [Re: tex013] #999814
05/25/11 10:21 PM
05/25/11 10:21 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Tex
If you like drag racing, support your local track.
Re: transmission breather relocation [Re: CHAPPER] #999815
05/25/11 10:28 PM
05/25/11 10:28 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
A 727 puke-tank ? ... whatthefugg youz guyz doin' ? ....injecting your TorkFlite with flatulent-gasses ??
Re: transmission breather relocation [Re: dOc !] #999816
05/25/11 11:06 PM
05/25/11 11:06 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Bill,Dartman,
thanks for the responce.
Bill i also will use a small catch can.
i am just a little leary of drilling in the web as the trans is not coming apart.i will be using an aluminium plug in the pump.
all goes well i will get the trans out this arvo
Doc,it drops about 5-10cc out of the bell housing after each pass,but only at the drags not when daily driven
Tex
PS: C4's have the breather on the extension housing though there is a cast baffle under it
New best MPH 130.32
Re: transmission breather relocation [Re: tex013] #999817
05/25/11 11:13 PM
05/25/11 11:13 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
hey. i drilled the main case about 10 oclock position. put a 1/8 pipe 90 fitting & ran a rubber hose up to the fire wall & put a allison vent on the end. no oil leakage. when launching, tranny oil gets pulled into the tail housing, that's not a good place to put the vent. stay safe, seeya, Rick.
Re: transmission breather relocation [Re: tex013] #999818
05/25/11 11:15 PM
05/25/11 11:15 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If done correctly the only thing you would have to take off would be the extention housing,, which if you drilled it then it would have to take it off anyway to clean out the chips,, when you drill the housing your not supposed to break into the internal area of the case, wish I had a pic of what I am talking about, it would be easier to understand.
Re: transmission breather relocation [Re: dartman366] #999819
05/25/11 11:28 PM
05/25/11 11:28 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
guess what,,I found one..
Re: transmission breather relocation [Re: dartman366] #999820
05/25/11 11:54 PM
05/25/11 11:54 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
If you do decide to use the tail shaft, Remember there is a fluid passage that runs along the top. It feeds fluid to the rear bushing for lubrication.
Re: transmission breather relocation [Re: WILD BILL] #999821
05/26/11 03:07 AM
05/26/11 03:07 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
like Bill i also run the tailshaft vent line up to a catch can. my catch can is a little smaller than Bills pic but does the same thing. it burps the system & when it's ready, it just drains back to the trans. i did have it in the main case but it always spewed fluid from there & we could never find why.
Re: transmission breather relocation [Re: rebel] #999822
05/26/11 11:28 PM
05/26/11 11:28 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks for all reply's.bit the bullet and fitted it in the case
hope this stops the drips
Tex
New best MPH 130.32
