Brake Pedal Stop #999805
05/25/11 06:51 PM
05/25/11 06:51 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
I am using an under floor booster and master cylinder setup. The master is a typical dual piston. Do I need an external stop on the pedal or is the stop on the master enough?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Brake Pedal Stop [Re: 36PLYM] #999806
05/26/11 10:21 AM
05/26/11 10:21 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
usually, it's tough to get a nice full stroke when adapting stuff around.
Have you considered the insulation and carpet under the pedal? That may be enough to prevent the master from being bottomed out.
Re: Brake Pedal Stop [Re: 36PLYM] #999807
05/26/11 04:45 PM
05/26/11 04:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Pedal stop, do you mean an up stop or down stop?
With properly working brakes there won't be an issue with a down stop, the MC should limit pedal down travel and the booster will limit the up travel.
Re: Brake Pedal Stop [Re: John_Kunkel] #999808
05/26/11 09:39 PM
05/26/11 09:39 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Up stop for pedal return.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Brake Pedal Stop [Re: 36PLYM] #999809
05/27/11 04:33 PM
05/27/11 04:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Every under-the-floor brake pedal that I've seen uses the underside of the toe board for an up stop; I'd design the pedal-to-booster pushrod length to do the same.
Re: Brake Pedal Stop [Re: John_Kunkel] #999810
05/27/11 06:22 PM
05/27/11 06:22 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Reason for the question, my pedal was way to high. I shortened the above mentioned rod which lowered the pedal. At the present it has no upper stop and seems to work fine. Grazie!
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
