Brake Pedal Stop
#999805
05/25/11 06:51 PM
05/25/11 06:51 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I am using an under floor booster and master cylinder setup. The master is a typical dual piston. Do I need an external stop on the pedal or is the stop on the master enough?
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: Brake Pedal Stop
[Re: 36PLYM]
#999807
05/26/11 04:45 PM
05/26/11 04:45 PM
Posts: 25,747 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Pedal stop, do you mean an up stop or down stop?
With properly working brakes there won't be an issue with a down stop, the MC should limit pedal down travel and the booster will limit the up travel.
[Re: John_Kunkel]
#999808
05/26/11 09:39 PM
05/26/11 09:39 PM
36PLYM
Lithonia, Ga
Up stop for pedal return.
[Re: 36PLYM]
#999809
05/27/11 04:33 PM
05/27/11 04:33 PM
John_Kunkel
Rio Linda, CA
Every under-the-floor brake pedal that I've seen uses the underside of the toe board for an up stop; I'd design the pedal-to-booster pushrod length to do the same.
[Re: John_Kunkel]
#999810
05/27/11 06:22 PM
05/27/11 06:22 PM
36PLYM
Lithonia, Ga
Reason for the question, my pedal was way to high. I shortened the above mentioned rod which lowered the pedal. At the present it has no upper stop and seems to work fine. Grazie!
