Installing TurboAction Cheetah Pro Street Manual/auto
#999652
05/25/11 01:28 PM
05/25/11 01:28 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang. I'm looking to get the TurboAction Cheetah Pro Street Manual/Automatic valvebody for the Daytona. It's been a while since I installed one, but had a question about other modifications to the 727. I know the installation of the valvebody itself is pretty straight forward, but what else is recommended? Do I remove the servo spring? Replace with a straight rod? etc... I remember doing something a long time ago, on a 727 I had in my '70 Charger R/T, but can't remember.
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Installing TurboAction Cheetah Pro Street Manual/auto
[Re: moparsquid]
#999654
05/25/11 02:59 PM
05/25/11 02:59 PM
hemi68charger
Houston, Tx
I dont believe there is anything else other than removing the kick down lever if its full manual I was going to install one on the 62 but it turned out to be full race.
I hear ya.. I'll be using the, what used to be called, the street/strip version. I'll have the positive shift pattern and fully automatic as well. So, I'll need the kickdown. I'll be putting a new mopar deep tranny fluid pan kit in as well. While I'm in there, I'll adjust the bands.
[Re: hemi68charger]
#999655
05/25/11 03:05 PM
05/25/11 03:05 PM
I installed the Pro-street version in my '63 330 and called them before I did it.
They recommended 3.2 Kickdown Lever for a transmission with a big Servo and 4.2 or 5.0 lever for one with the small servo (usally a part # on the side of the trans starting with PK34 for less).
They also said to used 12 springs in the front clutch retainer.
The last thing was 2 1/2 turns for the rear band adjustment (pretty much standard).
[Re: John_Kunkel]
#999660
05/25/11 07:55 PM
05/25/11 07:55 PM
hemi68charger
Houston, Tx
Thannks guys.. I'll do what I can from underneath without taking the tranny out. So I'll replace the valve body, adjust the bands and install the new Mopar deep pan kit. Cheers,,,
[Re: hemi68charger]
#999661
05/25/11 09:28 PM
05/25/11 09:28 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
If the mopar kit does not include the late style heavy duty pan gasket, get one of those too. Hard plastic with rubber inserts so the gasket can't push out.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
