Installing TurboAction Cheetah Pro Street Manual/auto #999652
05/25/11 01:28 PM
05/25/11 01:28 PM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang.
I'm looking to get the TurboAction Cheetah Pro Street Manual/Automatic valvebody for the Daytona. It's been a while since I installed one, but had a question about other modifications to the 727. I know the installation of the valvebody itself is pretty straight forward, but what else is recommended? Do I remove the servo spring? Replace with a straight rod? etc... I remember doing something a long time ago, on a 727 I had in my '70 Charger R/T, but can't remember.
Troy
Houston Mopar Connection Club
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: hemi68charger] #999653
05/25/11 02:48 PM
05/25/11 02:48 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
I dont believe there is anything else other than removing the kick down lever if its full manual I was going to install one on the 62 but it turned out to be full race.
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: moparsquid] #999654
05/25/11 02:59 PM
05/25/11 02:59 PM
Houston, Tx
Houston, Tx
I hear ya.. I'll be using the, what used to be called, the street/strip version. I'll have the positive shift pattern and fully automatic as well. So, I'll need the kickdown. I'll be putting a new mopar deep tranny fluid pan kit in as well. While I'm in there, I'll adjust the bands.
Troy
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: hemi68charger] #999655
05/25/11 03:05 PM
05/25/11 03:05 PM
I installed the Pro-street version in my '63 330 and called them before I did it.
They recommended 3.2 Kickdown Lever for a transmission with a big Servo and 4.2 or 5.0 lever for one with the small servo (usally a part # on the side of the trans starting with PK34 for less).
They also said to used 12 springs in the front clutch retainer.
The last thing was 2 1/2 turns for the rear band adjustment (pretty much standard).
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: hemi68charger] #999656
05/25/11 03:07 PM
05/25/11 03:07 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
You can download the instructions on the summit or Tubro Action website. I didn't replace the spring when I installed mine. as it was not in the installation instructions. FWIW mine works fine
Coming soon!!!!
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: Mr.Yuck] #999657
05/25/11 05:00 PM
05/25/11 05:00 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
I run that set-up in my Charger with 500+HP 440 and it works great. No crazy install tips here. I also did not install the spring and it has no issues.
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: hemi68charger] #999658
05/25/11 05:08 PM
05/25/11 05:08 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Drain the converter and put in all new fluid. When removing the valve body the spring above it is the accumulator spring and you can leave it out for more positive shifts. The servo springs are for the front and rear band pistons and you need those in there to return the pistons all the way. To change the front band lever the trand needs to be out of the car, remove converter and then you can access the plug and shaft to swap levers if you need to.
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: NANKET] #999659
05/25/11 07:45 PM
05/25/11 07:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope, oldest myth in the Mopar world.
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: John_Kunkel] #999660
05/25/11 07:55 PM
05/25/11 07:55 PM
Houston, Tx
Houston, Tx
Thannks guys.. I'll do what I can from underneath without taking the tranny out. So I'll replace the valve body, adjust the bands and install the new Mopar deep pan kit.
Cheers,,,
Troy
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: hemi68charger] #999661
05/25/11 09:28 PM
05/25/11 09:28 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
If the mopar kit does not include the late style heavy duty pan gasket, get one of those too. Hard plastic with rubber inserts so the gasket can't push out.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Installing TurboAction Cheetah Pro Street Manual/auto [Re: John_Kunkel] #999662
05/25/11 09:31 PM
05/25/11 09:31 PM
SW Missouri
moparmandjh Offline
Happy Birthday moparmandjh  Offline
SW Missouri
American soldiers in battle don't fight for what some president says on tv, they don't fight for mom, apple pie, or the American flag... they fight for one another. -Lt. General Hal Moore
