'07 PT, no park lights #999490
05/25/11 03:21 AM
05/25/11 03:21 AM
Missouri
MOBodyman Offline OP
Missouri
Just bought an '07 PT Cruiser and was checking all the lights. Everything works except the park lights. Car has fog lights and they work also.
Checked for blown fuses and found none.
Any ideas on what to test or look for?
TIA,
Dallas
2012 Rallye Redline Challenger, 1st new car!
2010 Ram 1500 4wd HEMI-hauler
2014 Dodge Dart-gas saver
4 projects and a bunch of parts cars, losing interest since buying the Challenger lol
1969 Dodge Coronet 500-'gonna fix 'er up someday!'
Re: '07 PT, no park lights [Re: MOBodyman] #999491
05/25/11 09:02 AM
05/25/11 09:02 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Did you check the bulbs?If the rears are working the frts might be bad.Its an easy check.Rocky
Chrysler Firepower
Re: '07 PT, no park lights [Re: therocks] #999492
05/25/11 10:25 AM
05/25/11 10:25 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
I'd guess the switch.
IIRC, the switch 'tells' the IPM (underhood fuse box or Intelligent Power Module) to turn them on.
Check/swap relays too.
Re: '07 PT, no park lights [Re: RodStRace] #999493
05/25/11 12:55 PM
05/25/11 12:55 PM
Missouri
Missouri
No park lights front or rear. I pulled every fuse out of the underhood fuse box and held them up to a light to check them, all were good.
I have a feeling it's the switch, just hoping I overlooked something.
Thanks for the replies,
Dallas
Re: '07 PT, no park lights [Re: MOBodyman] #999494
05/25/11 02:00 PM
05/25/11 02:00 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
You probably don`t want to know this, but, The lighting on those is WAY over complicated..The Steering column control module tells the cluster via the LIN bus and the cluster then tells the TIPM via Can bus to turn the lights on.
Don`t go throwing parts at it until you get some one with a REAL scan tool to see what faults, if any are in the SCCM,Cluster,TIPM
The TIPM has short circuit protection internally and uses solid state drivers so if it sees a problem it shuts them off.
Rick
Re: '07 PT, no park lights [Re: Blown71X] #999495
05/26/11 01:29 AM
05/26/11 01:29 AM
Missouri
Missouri
Rick
Thanks for the additional info. I'll check the wiring and see if I can find a short. The dash lights work so that kind of makes sense to me. I'm not too good with electrical issues so I may have to take it to the dealer.
Dallas
Re: '07 PT, no park lights [Re: MOBodyman] #999496
05/26/11 08:40 AM
05/26/11 08:40 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Its not just them its pretty much every new car made.Seems the engineers have to complicate anything that was simple.At least they arent as bad as GM with all the wiring problems in the headlights.I dont know how many Cavaliers and Sunfires I had to fix headlights on because they didnt work.Rocky
Chrysler Firepower
