Front wheel bearings, when to replace ? #999425
05/24/11 11:09 PM
05/24/11 11:09 PM
Walmart parking lot
yorker Offline OP
Drugs are bad
yorker  Offline OP
Drugs are bad
Walmart parking lot
Doing front brakes on a 68 Charger. Car has 45,000 original miles and may have the original wheel bearings .
I cleaned them and there is a little play between the inner circle and the outter part.
The right wheel did move a little when car was jacked up and hand placed on top of tire and at bottom. Could have been the main nut was not tightened properly.
I do not see any wear on the roller bearings them self.
Should these still be good for awhile, or are they near the end just because of age and mileage?
( SHONEN KNIFE ) MAKING THE WORLD A BETTER PLACE. ONE SONG, ONE CONCERT AT A TIME FOR OVER 36 YEARS!!
https://www.youtube.com/user/SHONENKNIFETV
Re: Front wheel bearings, when to replace ? [Re: yorker] #999426
05/24/11 11:14 PM
05/24/11 11:14 PM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Wheel bearings theoretically don't go bad if they are services regularly and properly. The looseness was no doubt caused by adjustment. If they look good with no gaulding or pitting, I'd run them. They are cheap enough to replace but chances are the modern quality is not as good as the originals.
Careful, your character's showing!
Re: Front wheel bearings, when to replace ? [Re: mopar346] #999427
05/24/11 11:26 PM
05/24/11 11:26 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
If they look good use them.
Re: Front wheel bearings, when to replace ? [Re: Neil] #999428
05/24/11 11:29 PM
05/24/11 11:29 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
The old ones are probably better quality than what you'd get new anyway.
Re: Front wheel bearings, when to replace ? [Re: slantzilla] #999429
05/24/11 11:48 PM
05/24/11 11:48 PM
Florida STAYcation
dOc … Offline
The village idiot's idiot
dOc …  Offline
Florida STAYcation
x 4 ... not to worry.
Re: Front wheel bearings, when to replace ? [Re: yorker] #999430
05/25/11 12:27 AM
05/25/11 12:27 AM
What they said. solvent clean/visual check/lube w Kendall GT "blue" grease or MP "green" grease & the needle ($5) on your grease gun works good esp on installed bearings (rear axle) and loose ones (front) the plastic 2 piece cone packer works good as does the needle but the packer is faster & cant use it on the installed ones. The bearings and their races will always be loose a fair amt
