Re: Front wheel bearings, when to replace ?
[Re: Neil]
#999428
05/24/11 11:29 PM
05/24/11 11:29 PM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
The old ones are probably better quality than what you'd get new anyway.
[Re: yorker]
#999430
05/25/11 12:27 AM
05/25/11 12:27 AM
RapidRobert
What they said. solvent clean/visual check/lube w Kendall GT "blue" grease or MP "green" grease & the needle ($5) on your grease gun works good esp on installed bearings (rear axle) and loose ones (front) the plastic 2 piece cone packer works good as does the needle but the packer is faster & cant use it on the installed ones. The bearings and their races will always be loose a fair amt
