904 tranny issues
#999232
05/24/11 05:02 PM
05/24/11 05:02 PM
Posts: 769 Europa, Estonia
Georg
Europa, Estonia
Hi guys
This is third time when my tranny needs repair and Iam tired of it. I cant understand whats wrong there...
I want to know some numbers to make sure everything is correct when I trie to rebuild it again
1. kickdown band torque : 45-50 inch-pound? 2. low and reverse band torque : 45-50 inch-pound? 3. line pressure in idle and kickdown lever closed : 51-59 psi? 4. front servo in idle and kickdown lever closed : over 45psi? 5. in idle and kickdown linkage "activated" Line pressure 88-9psi and front servo pressure over 80psi? 6. what have to be metal plates and friction plates gap in front clutch and low/reverse clutch when I install them???
I installed ( cutted low/reverse clutch drum in lathe and installed one set friction plate more in there and maybe there is the issue that those friction/metal plates are too tight and burn together ( to low end play ) ?
Thanks Georg
Outlaw Plymouth Valiant
R5/P7 Powered by Liuzzo Racing
COMP Performance Group dealer in Baltic
Premium Performance
Re: 904 tranny issues
[Re: Georg]
#999234
05/24/11 07:48 PM
05/24/11 07:48 PM
RapidRobert
What Scratch said on the bands and John Russo a former trans guru on here way back stated: .008-.0012" per disc on the front clutch and .015"-.035" per disc on the rear clutch
[Re: RapidRobert]
#999235
05/24/11 08:00 PM
05/24/11 08:00 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
.015"-.035" for the rear clutch is the total clearance, not the per disc clearance.
[Re: John_Kunkel]
#999236
05/24/11 08:18 PM
05/24/11 08:18 PM
RapidRobert
Thanks John, I copied it wrong . Is the front clutch part correct? EDIT (re)checked my notes and I had written 8-12 per disc on the front and 15-35 on the rear but I had not written next to the rear specs that that was per disc & I just assumed it was per disc. Thank you for the correction as I was going to use that on my next one
[Re: Evil Spirit]
#999239
05/25/11 01:55 AM
05/25/11 01:55 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
Georg, as to your question about measuring your clutch clearance - I usually assemble the drum, then measure the gap by inserting feeler gauges between the top cover plate and the snap ring. You can adjust the clearance by using different thickness snap rings or steels. I do not use the wavy snap rings in either drum, but you can use in the rear (low/reverse) if you have to. I'm not quite sure what you were trying to do with your low/reverse drum by machining it. In forward gears - once it's applied, it stays applied - it's not a shifting clutch like the front drum. 4 disc drums are common and all you need for most applications. Hope this helps.
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#999244
05/26/11 12:40 AM
05/26/11 12:40 AM
RapidRobert
Yeah I didn't see the decimal point error so I thought I was being jumped on for no legitimate reason. That math mistake could have been disastrous esp for Georg's 4th rebuild . Thanks for clearing that up.
[Re: RapidRobert]
#999245
05/26/11 04:37 PM
05/26/11 04:37 PM
Georg
Europa, Estonia
guys,guys...dont fight now I understood what you mentioned. I write those numbers down and trie to get this d``n tranny running now for a long time Thanks a lot!
Premium Performance
