What Scratch said on the bands and John Russo a former trans guru on here way back stated: .008-.0012" per disc on the front clutch and .015"-.035" per disc on the rear clutch
Thanks John, I copied it wrong . Is the front clutch part correct? EDIT (re)checked my notes and I had written 8-12 per disc on the front and 15-35 on the rear but I had not written next to the rear specs that that was per disc & I just assumed it was per disc. Thank you for the correction as I was going to use that on my next one
Front is wrong, also - it's NOT .008-.0012, its .008-.012 per friction disc
Free advice and worth every penny... Factory trained Slinky rewinder.........
