Intake/Camshaft RPM range on a stroker
#999198
05/24/11 04:31 PM
05/24/11 04:31 PM
Posts: 288 Birmingham, England
Mick70RR
Birmingham, England
Am I right in thinking that the quoted RPM range of an intake is based on airflow, and if it's used on a stroker, the actual RPM range will be lower? Since a 505 is 15 percent bigger than a 440, would the RPM range be 15 percent lower than the advertised range? If so, would it be the same with the rated RPM range for a camshaft?
1970 Road Runner
505 cid
MCH CNC ported Stealth heads
MP 528 camshaft
4 speed
GV overdrive
11.98 @ 117 on street treads
Re: Intake/Camshaft RPM range on a stroker
[Re: Mick70RR]
#999200
05/24/11 07:37 PM
05/24/11 07:37 PM
RapidRobert
Dont know if this helps but w a stroker you have the incr in swept vol of course and the faster piston speed however that would affect it which I think might b that it'd reach peak volumetric efficiency at a lower rpm
[Re: Mick70RR]
#999201
05/24/11 08:41 PM
05/24/11 08:41 PM
Posts: 3,140 Central NC
gch
Central NC
There are a lot of other variables at play here.Compression,head flow,carb cfm,reciprocating assembly weight,valvetrain weight,etc. The same cam in a 383 will likely turn 300-500rpm higher than it will in a 440.Go from 440-496 and it will likely drop another 300-500rpm. I don't think you can put a % on it. The bigger the motor the more airflow is needed to gain all the hp/tq increase it is capable of so long as you don't go too big and start to lose velocity and efficiency.
[Re: Mick70RR]
#999202
05/25/11 12:01 PM
05/25/11 12:01 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
It definitely affects cam, intake and the heads. the operating range or sweet spot drops. From my observations it will affect it by 2/3 of the % in cubic inch increase so in this case 10% it will lower peak tort by 10% say it was a 5000 it will drop to 4500 and say peak hp is 5800 it will drop to 5200 using the same heads cam and intake. making only a Cubic inch change. a 446 to a 505 will make the cam act about 20 deg less duration. Just My
[Re: AndyF]
#999204
05/25/11 03:50 PM
05/25/11 03:50 PM
Mick70RR
Birmingham, England
Thanks for the replies. Andy, I've got your book, I'll have another look later.
1970 Road Runner
505 cid
MP 528 camshaft
4 speed
GV overdrive
