Intake/Camshaft RPM range on a stroker #999198
05/24/11 04:31 PM
05/24/11 04:31 PM
Birmingham, England
Mick70RR Offline OP
Mick70RR  Offline OP
Birmingham, England
Am I right in thinking that the quoted RPM range of an intake is based on airflow, and if it's used on a stroker, the actual RPM range will be lower? Since a 505 is 15 percent bigger than a 440, would the RPM range be 15 percent lower than the advertised range?
If so, would it be the same with the rated RPM range for a camshaft?
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Intake/Camshaft RPM range on a stroker [Re: Mick70RR] #999199
05/24/11 04:44 PM
05/24/11 04:44 PM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I am also very interested in this subject. I am almost positive you are correct about the drop in rated RPM range but I don't know of any way to calculate it.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: Intake/Camshaft RPM range on a stroker [Re: Mick70RR] #999200
05/24/11 07:37 PM
05/24/11 07:37 PM
Dont know if this helps but w a stroker you have the incr in swept vol of course and the faster piston speed however that would affect it which I think might b that it'd reach peak volumetric efficiency at a lower rpm
Re: Intake/Camshaft RPM range on a stroker [Re: Mick70RR] #999201
05/24/11 08:41 PM
05/24/11 08:41 PM
Central NC
gch Offline
gch  Offline
Central NC
There are a lot of other variables at play here.Compression,head flow,carb cfm,reciprocating assembly weight,valvetrain weight,etc.
The same cam in a 383 will likely turn 300-500rpm higher than it will in a 440.Go from 440-496 and it will likely drop another 300-500rpm.
I don't think you can put a % on it.
The bigger the motor the more airflow is needed to gain all the hp/tq increase it is capable of so long as you don't go too big and start to lose velocity and efficiency.
Re: Intake/Camshaft RPM range on a stroker [Re: Mick70RR] #999202
05/25/11 12:01 PM
05/25/11 12:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
It definitely affects cam, intake and the heads. the operating range or sweet spot drops. From my observations it will affect it by 2/3 of the % in cubic inch increase so in this case 10% it will lower peak tort by 10% say it was a 5000 it will drop to 4500 and say peak hp is 5800 it will drop to 5200 using the same heads cam and intake. making only a Cubic inch change.
a 446 to a 505 will make the cam act about 20 deg less duration.
Just My
Re: Intake/Camshaft RPM range on a stroker [Re: Mick70RR] #999203
05/25/11 12:12 PM
05/25/11 12:12 PM
AndyF Offline
AndyF  Offline
Torque peak RPM is closely related to the CSA of the induction system. I covered that in my big block book since it is an important part of picking the right heads for a stroker motor.
Re: Intake/Camshaft RPM range on a stroker [Re: AndyF] #999204
05/25/11 03:50 PM
05/25/11 03:50 PM
Birmingham, England
Mick70RR Offline OP
Mick70RR  Offline OP
Birmingham, England
Thanks for the replies.
Andy, I've got your book, I'll have another look later.
