Anyone drilled SB Eddy exhaust side to Indy/W2 pattern? #999052
05/24/11 03:06 PM
05/24/11 03:06 PM
Renton Wa
topfueldart Offline OP
Renton Wa
In my case it would be for mocking up Indy flanged turbo kits, so, has it ever been done? Thanks
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: topfueldart] #999053
05/25/11 12:11 AM
05/25/11 12:11 AM
Renton Wa
Renton Wa
Anyone?
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: topfueldart] #999054
05/25/11 12:20 AM
05/25/11 12:20 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Can you use the adapter plates that hedman offers to run there W2 headers on other small block heads. If you need a picture of a set let me know.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: pittsburghracer] #999055
05/25/11 12:23 AM
05/25/11 12:23 AM
PA.
"Little"John
"Little"John
PA.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: pittsburghracer] #999056
05/25/11 02:16 AM
05/25/11 02:16 AM
Renton Wa
Renton Wa
Unfortunately not, there is very limited space on the passenger side and the spacers would force the header into the Inner fenderwell.
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: topfueldart] #999057
05/25/11 11:44 PM
05/25/11 11:44 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
looks like your gonna be the first innovator, good luck
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt [Re: Stroker Scamp] #999058
05/25/11 11:46 PM
05/25/11 11:46 PM
Renton Wa
Renton Wa
Maybe, we'll see!
