Anyone drilled SB Eddy exhaust side to Indy/W2 pattern?
#999052
05/24/11 03:06 PM
05/24/11 03:06 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
In my case it would be for mocking up Indy flanged turbo kits, so, has it ever been done? Thanks
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Anyone drilled SB Eddy exhaust side to Indy/W2 patt
[Re: topfueldart]
#999053
05/25/11 12:11 AM
05/25/11 12:11 AM
topfueldart
Renton Wa
[Re: topfueldart]
#999054
05/25/11 12:20 AM
05/25/11 12:20 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Can you use the adapter plates that hedman offers to run there W2 headers on other small block heads. If you need a picture of a set let me know.
[Re: pittsburghracer]
#999056
05/25/11 02:16 AM
05/25/11 02:16 AM
topfueldart
Renton Wa
Unfortunately not, there is very limited space on the passenger side and the spacers would force the header into the Inner fenderwell.
[Re: Stroker Scamp]
#999058
05/25/11 11:46 PM
05/25/11 11:46 PM
topfueldart
Renton Wa
Maybe, we'll see!
