Re: Sand epoxy primer prior to filler ?
[Re: RTshaker]
#999046
05/24/11 04:41 PM
05/24/11 04:41 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Yes you MUST scuff once its completely dry. Scuff with green or red "scuff" pad or 220--280 dry paper.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: elitecustombody]
#999048
05/25/11 01:08 PM
05/25/11 01:08 PM
Posts: 330 Frederiction. New Brunswick ,C...
RTshaker
yes that is what I was getting at. The window is 72 hrs before requiring sanding..but then started to wonder if the epoxy is NOT completely dry then maybe it wouldn`t be wise to put the plastic on ??
