Place to get new 1969 RoadRunner Gas Tank #998997
05/24/11 12:15 PM
05/24/11 12:15 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Where would be the best place to get a gas tank and bolts/straps/sending unit for a 1969 Roadrunner? I need to pull a fuel cell out and replace with a regular tank.
1967 Barracuda Formula S 383
1967 Chevy C10 Short Stepper
1980 Macho Power Wagon LWB 318
2021 Toyota Supra
Re: Place to get new 1969 RoadRunner Gas Tank [Re: grancuda] #998998
05/24/11 01:15 PM
05/24/11 01:15 PM
WI, NC
mk2 Offline
mk2  Offline
WI, NC
Vans Auto in Watertown WI.
Re: Place to get new 1969 RoadRunner Gas Tank [Re: mk2] #998999
05/24/11 01:26 PM
05/24/11 01:26 PM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Cool!
2021 Toyota Supra
Re: Place to get new 1969 RoadRunner Gas Tank [Re: grancuda] #999000
05/24/11 09:35 PM
05/24/11 09:35 PM
southern conn
1969gtx Offline
1969gtx  Offline
southern conn
rock auto .com
1965 A/FX Plymouth 9.50 et @139 mph
1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi
1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM
1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM
http://www.AFXER.com
Re: Place to get new 1969 RoadRunner Gas Tank [Re: 1969gtx] #999001
05/25/11 08:31 AM
05/25/11 08:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
just be carefull,,,,, some of the repop tanks out there are not plated as OE but instead are just painted.
IF it matters to you
I've bought all mine thru Quanta at gastanks.com
Re: Place to get new 1969 RoadRunner Gas Tank [Re: gtx6970] #999002
05/25/11 08:35 AM
05/25/11 08:35 AM
MD, Northern VA
Z
zrwhat Offline
zrwhat  Offline
Z
MD, Northern VA
I second Quanta as a reliable source for a replacement tank, way up there quality wise and as close as you'll get without going NOS!
Re: Place to get new 1969 RoadRunner Gas Tank [Re: zrwhat] #999003
05/26/11 08:51 AM
05/26/11 08:51 AM
Central US
grancuda Offline OP
grancuda  Offline OP
Central US
Is the filler neck weled onto a '69 RR gas tank or is that something I will need also? All I have is a fuel cell so nothing to reference.
2021 Toyota Supra
Re: Place to get new 1969 RoadRunner Gas Tank [Re: grancuda] #999004
05/26/11 08:54 AM
05/26/11 08:54 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Is the filler neck welded onto a '69 RR gas tank or is that something I will need also? All I have is a fuel cell so nothing to reference.
No, the filler neck is a seperate piece.
It's avail thru Tonysparts.com
