Place to get new 1969 RoadRunner Gas Tank
#998997
05/24/11 12:15 PM
05/24/11 12:15 PM
Posts: 1,009 Central US
grancuda
Central US
Where would be the best place to get a gas tank and bolts/straps/sending unit for a 1969 Roadrunner? I need to pull a fuel cell out and replace with a regular tank.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: Place to get new 1969 RoadRunner Gas Tank
[Re: grancuda]
#999000
05/24/11 09:35 PM
05/24/11 09:35 PM
Posts: 643 southern conn
1969gtx
southern conn
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
[Re: gtx6970]
#999002
05/25/11 08:35 AM
05/25/11 08:35 AM
Posts: 66 MD, Northern VA
zrwhat
MD, Northern VA
just be carefull,,,,, some of the repop tanks out there are not plated as OE but instead are just painted. IF it matters to you
I've bought all mine thru Quanta at gastanks.com
I second Quanta as a reliable source for a replacement tank, way up there quality wise and as close as you'll get without going NOS!
[Re: zrwhat]
#999003
05/26/11 08:51 AM
05/26/11 08:51 AM
grancuda
Central US
Is the filler neck weled onto a '69 RR gas tank or is that something I will need also? All I have is a fuel cell so nothing to reference.
[Re: grancuda]
#999004
05/26/11 08:54 AM
05/26/11 08:54 AM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
Is the filler neck welded onto a '69 RR gas tank or is that something I will need also? All I have is a fuel cell so nothing to reference.
No, the filler neck is a seperate piece. It's avail thru Tonysparts.com
