rear main seal install direction #998907
05/24/11 10:12 AM
05/24/11 10:12 AM
PA
BTTG Offline OP
BTTG  Offline OP
PA
just to confirm before installing the right side (in picture) of this rear main seal faces towards the #3 main cap.....tapered edge (left in photo) towards the bellhousing?
Re: rear main seal install direction [Re: BTTG] #998908
05/24/11 10:17 AM
05/24/11 10:17 AM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
The right side faces #5 main brng cap and other side the bellhousing.
Re: rear main seal install direction [Re: Hemi_Ram] #998909
05/24/11 10:21 AM
05/24/11 10:21 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Agreed, the right side of the image shown, goes towards front of the engine.
Re: rear main seal install direction [Re: buildanother] #998910
05/24/11 03:21 PM
05/24/11 03:21 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Agree,
Just remember on all seals the lip towards the oil
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: rear main seal install direction [Re: moparts] #998911
05/24/11 04:28 PM
05/24/11 04:28 PM
Just look at it like it was a dam on a river, you have the flat wall that faces the fluid to b contained then a tapered wall on the back side to support it
Re: rear main seal install direction [Re: RapidRobert] #998912
05/24/11 05:46 PM
05/24/11 05:46 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Seal lip toward oil, <- ]
So that any internal oil force toward will tend to spread the lips to the sealing surface of the shaft. If the oil force hits on the tapered side of the seal it would tend to 'crush' it outward away from the sealing surface of the shaft and open up letting the oil flow past.
Re: rear main seal install direction [Re: MoparforLife] #998913
05/24/11 06:27 PM
05/24/11 06:27 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Lip orientation
The lip on the rear main seal should point toward the crankshaft and not towards the back of the engine. The lip on the seal is designed to allow oil pressure to force the seal against the crankshaft, improving its sealing capability. When the seal is pointed the wrong way, it allows oil pressure to force oil past the seal, resulting in a leak
Re: rear main seal install direction [Re: BTTG] #998914
05/25/11 11:13 AM
05/25/11 11:13 AM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Hard to see, but like they said facing in towards #5 main
Re: rear main seal install direction [Re: R/T1968R/T] #998915
05/25/11 11:58 AM
05/25/11 11:58 AM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
If you still have a leak after replacing the seal, don't just do the job again. You need to look deeper there might be a loose cam bearing that is spinning, blocking the oil passage way. This would cause added increase in oil pressure that gets past the seal. This news sux, but it hurts less than beating your head against a wall.
Re: rear main seal install direction [Re: convx4] #998916
05/25/11 01:00 PM
05/25/11 01:00 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A loose cam bearing wouldn't cause a rise in oil pressure that would blow past the seal.
Re: rear main seal install direction [Re: stumpy] #998917
05/25/11 01:25 PM
05/25/11 01:25 PM
Northern Va
Mopar73340 Offline
Mopar73340  Offline
Northern Va
MP also used to make a rear main bearing that was supposed to help reduce the chance of the seal leaking. It had to grooves cut in the lower half to direct oil away from the seal. (I don't know the part # off hand). I just had this issue with my 408. I had the black seal as in the picture above and it leaked for no apparent reason. I replaced it with the orange style one as in the picture earlier in this thread and duplicated the rear main bearing like the MP unit and it solved the problem.
Re: rear main seal install direction [Re: Mopar73340] #998918
05/25/11 04:30 PM
05/25/11 04:30 PM
Haven't used it myself but several posters have & it fixed the leak though I'd think proper use of a seal/sealer should take care of it & would b a better way of dealing w it exp as there's the oil pan junction nearby & you dont want a leak from there (or anywhere)
Re: rear main seal install direction [Re: Mopar73340] #998919
05/26/11 02:05 AM
05/26/11 02:05 AM
Montreal PQ, Canada
74_360_Cuda Offline
74_360_Cuda  Offline
Montreal PQ, Canada
+1 The Magnum orange seal (P/N 4798216AC) did it for me as well
This seal has two lips, the small one is a dust shield and goes toward the bellhousing. Also, install it 1/4 inch offset so the the joint is not located between the cap & the block...
Re: rear main seal install direction [Re: 74_360_Cuda] #998920
05/26/11 08:25 AM
05/26/11 08:25 AM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
Good information to now!!!
