Does mini-starter crank faster? #998724
05/23/11 10:10 PM
05/23/11 10:10 PM
BDW Offline OP
BDW  Offline OP
I understand the weight savings.
Does the mini-starter turn the engine over any faster compared to the early style factory starters?
Curious is this would help, hot start, fuel evaporation issues?
Thx
Re: Does mini-starter crank faster? [Re: BDW] #998725
05/23/11 10:24 PM
05/23/11 10:24 PM
scratchnfotraction Offline
yes,it does on my 318 and 440
Re: Does mini-starter crank faster? [Re: scratchnfotraction] #998726
05/23/11 11:18 PM
05/23/11 11:18 PM
Bowling Green, KY
K
KY Charger Offline
KY Charger  Offline
K
Bowling Green, KY
Yes they don't drag as much as the old starters and you might just need an aluminum spacer between your intake and carb.
Re: Does mini-starter crank faster? [Re: BDW] #998727
05/23/11 11:25 PM
05/23/11 11:25 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Seems like mine spins twice as fast. I know it really doesn't, but it seems like it. Engine starts so much quicker.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Does mini-starter crank faster? [Re: BDW] #998728
05/23/11 11:30 PM
05/23/11 11:30 PM
I'd b inclined to think that (prob) needs (seperate) attention. More details on what you have, carb/spacer/ex heat/E10 or not
Re: Does mini-starter crank faster? [Re: Junky] #998729
05/24/11 12:10 PM
05/24/11 12:10 PM
Lost in the ozone again
stubbs300 Offline
Vacation
stubbs300  Offline
Vacation
Re: Does mini-starter crank faster? [Re: BDW] #998730
05/24/11 01:59 PM
05/24/11 01:59 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
it spins faster, but doesnt effect the fuel system. you might need a phenolic or plywood spacer under the carb. you're in florida, and that means you can find gas without alcohol in it. the pump handles are blue, on a "real gas" pump. green is diesel, black is blended fuel. run real gas when you can, and insulate the carb.
Re: Does mini-starter crank faster? [Re: Golden-Arm] #998731
05/24/11 09:11 PM
05/24/11 09:11 PM
BDW Offline OP
BDW  Offline OP
Car actually starts pretty good. The addition of the Edlebrock spacer worked wonders.
There's just some times it seems like the starter is slow and car would start better if it turned over quicker.
Re: Does mini-starter crank faster? [Re: BDW] #998732
05/24/11 11:19 PM
05/24/11 11:19 PM
Car actually starts pretty good. There's just some times it seems like the starter is slow and car would start better if it turned over quicker.
W that info a mini might b a good addition and the slower a starter turns the more amps it draws (unlike most motors) so a faster/more efficient mini would free up more voltage for the ign
Re: Does mini-starter crank faster? [Re: RapidRobert] #998733
05/25/11 12:50 AM
05/25/11 12:50 AM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Yes!! For sure!
I put one on everything for that very reason.
Re: Does mini-starter crank faster? [Re: DusterKrazy] #998734
05/25/11 08:34 AM
05/25/11 08:34 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
do they spin faster? yup.
another problem that you might be having is that the starter is getting heat soaked and the internal resistance goes up, making it crank slower.
a smaller starter will also help with this, as it leaves more air space between the exhaust and starter.
**Photobucket sucks**
Re: Does mini-starter crank faster? [Re: 70Cuda383] #998735
05/25/11 12:13 PM
05/25/11 12:13 PM
St Louis, MO 63026
convx4 Offline
convx4  Offline
St Louis, MO 63026
I'm going to break the trend.
And say No.
Let me explain:
I have a manual RPM gauge. I removed the distributor cap and rotor. Then checked the cranking speed on my original 1965 starter. It was about 100 RPM's
After installing a rebuilt mini starter from a 1996 dodge truck it read 50 RPM's.
I did make a new wiring harness for the mini starter.
Yes the battery was fully charged. The mini starter sounds a lot faster than the old gear reduction starter.
I did this testing cause I was having a hard start problem with my electronic distributor. Om my Allen distributor machine I was getting a good signal at 200 RPM. It turned out to be my replacement magnetic pickup was bad. I want to, but haven't, go back with the original starter. I just like that sound.
Re: Does mini-starter crank faster? [Re: convx4] #998736
05/25/11 09:56 PM
05/25/11 09:56 PM
BDW Offline OP
BDW  Offline OP
Thx for all the replies.
Anyone have a pic of the mini-starter on a SB? I see the connector terminal is clocked differently and is closer to the block?
Can I use my factory battery cable without cutting or modding it?
Re: Does mini-starter crank faster? [Re: BDW] #998737
05/25/11 10:03 PM
05/25/11 10:03 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
You should see how close it is the block on B-RB engines. The cable has to reach a little farther to bolt to your new starter, and has to be twisted a little too. I just got the stock cable to work on a 79 d150, but it is a little short. Some starters had a plastic adapter on them for better fitment though.
Re: Does mini-starter crank faster? [Re: BDW] #998738
05/25/11 11:09 PM
05/25/11 11:09 PM
hers one on my 440 truck with stock wire with rubber lug
it looks close to the block,but the stud is in the center of the core plug and has a finger thickness of clearance to touch the block or core plug
just removed the adaptor extition piece and put the stock wire right to the studs
might have to grind a little at the screw on the noid at the starter bolt flange thats the only tight spot on mine...i did notheing to it though
