AM-FM wires, what is what? #998430
05/23/11 03:50 PM
05/23/11 03:50 PM
Motown, Mi
P
PAULS_340 Offline OP
P
Motown, Mi
Can anyone tell me where these wires connect to ? It's an AM-FM radio. Thanks. PM me if you're a radio expert.
Still looking for LM29H1B415501, '71 Demon 340
Re: AM-FM wires, what is what? [Re: PAULS_340] #998431
05/23/11 04:14 PM
05/23/11 04:14 PM
Mansfield, TEXAS
JOES4FORTY Offline
JOES4FORTY  Offline
Mansfield, TEXAS
I believe the black and green are for your speaker an the red/red orange is your power connection.
The GTS Registry!
MOPARTS MEMBER IN PRINT
1969 Dart GTS LS23P9B (First day of production car money pit)
Re: AM-FM wires, what is what? [Re: PAULS_340] #998432
05/23/11 04:15 PM
05/23/11 04:15 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Red is switched 12volt power, orange is face lighting, black and green are the power and ground for one speaker. Must be a mono radio, no?
Re: AM-FM wires, what is what? [Re: JOES4FORTY] #998433
05/23/11 04:16 PM
05/23/11 04:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What he said , red is radio power , orange is the light , ground to the chassis , the green and black are the single speaker.
Re: AM-FM wires, what is what? [Re: JohnRR] #998434
05/23/11 05:30 PM
05/23/11 05:30 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
yes is a amfm mono radio,
stereo am fm is 1 red 1 orange 1 green 1 green black wire and 1 purple wire
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: AM-FM wires, what is what? [Re: 440beep] #998435
05/23/11 05:33 PM
05/23/11 05:33 PM
Alabama
BigMoneyLewis Offline
Alabama
As already mentioned, red is power. orange is dial light.
Green is speaker + , black is speaker -.
The easiest way to do it is to just simply plug the connectors in .
You should have a red /orange plug hanging under your dash VERY near your radio, Just plug it in . Then plug the speaker wires into the dash speaker .
Greg
gregward@mchsi.com phone 256-852-0955
Re: AM-FM wires, what is what? [Re: BigMoneyLewis] #998436
05/23/11 09:18 PM
05/23/11 09:18 PM
Motown, Mi
P
P
Motown, Mi
What if I add two rear speakers? Do they get hooked to the black/green?
Re: AM-FM wires, what is what? [Re: PAULS_340] #998437
05/23/11 09:24 PM
05/23/11 09:24 PM
Toronto, Ontario, Canada
plazomat Offline
plazomat  Offline
If it was a mono radio with one set of speaker outputs, be careful with adding more than one speaker...if u add too low an impedance you will do damage to that vintage radio.
Better option would be a cheap audio amp that takes speaker level inputs and boosts power. the input impedance should be high on those units allowing you to paralell the inputs with out issue...again check check check or you will have to write a cheque...
PLAZ
Re: AM-FM wires, what is what? [Re: plazomat] #998438
05/24/11 04:27 AM
05/24/11 04:27 AM
Alabama
Alabama
You can use a factory fader switch and run the single dash and single rear speaker. That was a factory option for mono radios. A factory fader switch is the the best way to go in order to run two speakers without altering the impedance .You always want to be sure to maintain 8 ohms with these old radios.
When you start hooking speakers up in parallel or in series, you change the impedance. If you drop down to 4 ohms you run a risk of overheating the radio's output transformer.
Greg
