Page 3 of 3 1 2 3
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: dragram440] #998159
05/25/11 05:32 PM
05/25/11 05:32 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Can't see throwing down for an aftermarket block yet.
So for me, a pump gas, OEM production B or RB block with a 4.15 stroker kit is the plan.................after much evaluation of what's out there, it'll be a set of the Indy EZ's. They have the improved intake runner/passage, taller valves, aluminum (weight savings), will fit either my A or B body, takes a wide selection of standard valvetrain/rocker gear and can be ported to MW inlets later.
The complete kit is here.........http://chucker54.stores.yahoo.net/indyezheads1.html
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: Dean_Kuzluzski] #998160
05/25/11 10:18 PM
05/25/11 10:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I think The EZ's are the best head for the money with room to grow
It would be easy to put a car into the nines with them and not have to spend a lot of money on high dollar parts
Gus
64 Plymouth Savoy
Dana 60
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: fourgearsavoy] #998161
05/25/11 10:37 PM
05/25/11 10:37 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I'd like to know what the problem was with the stage IV's in the 1st place
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: Cab_Burge] #998162
05/26/11 01:08 AM
05/26/11 01:08 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
Mr cab my cuda is race only bracket car. the reason i have had to redo them twice is the intakes are leaking during a leakdown test. It seems the seats are dropping.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998163
05/26/11 02:09 AM
05/26/11 02:09 AM
It sounds like the seats are moving around when running or warmed up I wonder how soon it will be before one falls all the way out I have used B1-BS, Indy SR M.W. port size, Indy 440-1 CNC ported, Eddy RPM stock and CNC ported on two different motors all made good power, the bigger the ports(air flow) the more power you can make I have a new set of Koffels original B1 that they ported for me which I haven't use yet I'm waiting for a really good iron block to use them on It depends on how much power you want the heads to make and how big the motor is Lots of choices out there
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998164
05/26/11 03:23 AM
05/26/11 03:23 AM
Arizona
Chris'sBarracuda Offline
Arizona
Send them to a reputable shop and have new seats put in. Much cheaper in the long run.
Porter, Koffel, Radar come to mind.
My 3000# 500" Barracuda went 9.20's with Stage VI M/W ported heads. However, they were done by Don Studley, who is not with us any more.
But the first thing he did was put new seats in new heads..
Wonder why that was..
Chris..
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: MRMOPAR622] #998165
05/26/11 10:34 AM
05/26/11 10:34 AM
gregsdart Offline
gregsdart  Offline
A buddy had a set of pro comps set up to race with. The guy at the shop said it would be best to work with them basically bare with valves for a race deal. They did make good power after some port work though. But that is only one set of heads. As they say, results may vary.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: Chris'sBarracuda] #998166
05/26/11 10:38 AM
05/26/11 10:38 AM
tboomer Online work
tboomer  Online Work
Chris is correct..I would send your Stage VI heads to Dwayne Porter or Radar...If Jeff at Modern Cylinder was well,he would also be a great choice!
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: gregsdart] #998167
05/26/11 02:40 PM
05/26/11 02:40 PM
Mo.
supercomp Offline
supercomp  Offline
Mo.
We used a set of bare cnc ported pro comps and had Mike Chenoweth to plane to 60cc's and do the valve job using Ferrea valves. We're setting them up with trick flow pacaloy roller springs, comp spring cups, retainers, locks and T&D rocckers. Turned out nice. Going on a 451.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: tboomer] #998168
05/26/11 05:50 PM
05/26/11 05:50 PM
Woodburn,OR
W
Womanator Offline
Womanator  Offline
W
Woodburn,OR
I am running the SR's
Solid cam in the .650 range
Ran a best of 9.59
499 ci engine.
230 cold block
300 plus pass's on the block
Ported heads this year,more comp,bigger roller cam and upgraded the valve gear.
Lightened car more
Looking for low nines
All this with Sr heads
T and D rockers
I was at 756 hp before the new mods
The sr's worked out for me
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: Chris'sBarracuda] #998169
05/27/11 12:57 AM
05/27/11 12:57 AM
Rapid City, SD
rickb67 Offline OP
rickb67  Offline OP
Rapid City, SD
I did talk to Dwayne at Porters. I am gonna race this year with the 440 and stage VIs and then this fall I will send Dwayne the heads and he will make them right. I didn't race at all last year so it is time. Told my son to get his duster ready cause we are going to mopars on the strip in 2 years.
Re: BEST BIG BLOCK HEADS FOR THE MONEY [Re: rickb67] #998170
05/27/11 06:53 AM
05/27/11 06:53 AM
mohnton pa
rva Offline
super gas
rva  Offline
super gas
mohnton pa
Page 3 of 3 1 2 3
