Re: BEST BIG BLOCK HEADS FOR THE MONEY
[Re: dragram440]
#998159
05/25/11 05:32 PM
05/25/11 05:32 PM
Posts: 8,940 Holly/MI
Dean_Kuzluzski
Holly/MI
Can't see throwing down for an aftermarket block yet.
So for me, a pump gas, OEM production B or RB block with a 4.15 stroker kit is the plan.................after much evaluation of what's out there, it'll be a set of the Indy EZ's. They have the improved intake runner/passage, taller valves, aluminum (weight savings), will fit either my A or B body, takes a wide selection of standard valvetrain/rocker gear and can be ported to MW inlets later.
The complete kit is here.........http://chucker54.stores.yahoo.net/indyezheads1.html
[Re: Dean_Kuzluzski]
#998160
05/25/11 10:18 PM
05/25/11 10:18 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I think The EZ's are the best head for the money with room to grow It would be easy to put a car into the nines with them and not have to spend a lot of money on high dollar parts Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: rickb67]
#998164
05/26/11 03:23 AM
05/26/11 03:23 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Mr cab my cuda is race only bracket car. the reason i have had to redo them twice is the intakes are leaking during a leakdown test. It seems the seats are dropping.
Send them to a reputable shop and have new seats put in. Much cheaper in the long run.
Porter, Koffel, Radar come to mind.
My 3000# 500" Barracuda went 9.20's with Stage VI M/W ported heads. However, they were done by Don Studley, who is not with us any more.
But the first thing he did was put new seats in new heads..
Wonder why that was..
Chris..
[Re: MRMOPAR622]
#998165
05/26/11 10:34 AM
05/26/11 10:34 AM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A buddy had a set of pro comps set up to race with. The guy at the shop said it would be best to work with them basically bare with valves for a race deal. They did make good power after some port work though. But that is only one set of heads. As they say, results may vary.
[Re: tboomer]
#998168
05/26/11 05:50 PM
05/26/11 05:50 PM
Posts: 40 Woodburn,OR
Womanator
Woodburn,OR
I am running the SR's Solid cam in the .650 range Ran a best of 9.59 499 ci engine. 230 cold block 300 plus pass's on the block Ported heads this year,more comp,bigger roller cam and upgraded the valve gear. Lightened car more Looking for low nines All this with Sr heads T and D rockers I was at 756 hp before the new mods The sr's worked out for me
[Re: rickb67]
#998170
05/27/11 06:53 AM
05/27/11 06:53 AM
Posts: 791 mohnton pa
rva
super gas
super gas
mohnton pa
I did talk to Dwayne at Porters. I am gonna race this year with the 440 and stage VIs and then this fall I will send Dwayne the heads and he will make them right. I didn't race at all last year so it is time. Told my son to get his duster ready cause we are going to mopars on the strip in 2 years.
