Re: OK.............Let's see a show of hands. [Re: Cab_Burge] #997556
05/23/11 10:12 AM
05/23/11 10:12 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
it's a hateful job that got to be done and done right !
Re: OK.............Let's see a show of hands. [Re: VernMotor] #997557
05/23/11 10:30 AM
05/23/11 10:30 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
That grinder would be great when cutting Tool Steel rings for large gaps on nitrous engines. I have actually had to use a cut off wheel to get close then start grinding with the ring grinder.
Buy a new set of rings due to one being a little big??? How big?? I would have probably used that ring in a hole I new got hotter than others.
Leon
Re: OK.............Let's see a show of hands. [Re: efisixpack] #997558
05/23/11 07:20 PM
05/23/11 07:20 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
who has the best tool for grinding ring? Also, what is the best way to debur rings?
ABS has the best ring filer that I have used and know of, it has a rotating deburr brush already on it.
Re: OK.............Let's see a show of hands. [Re: LSP] #997559
05/24/11 12:11 AM
05/24/11 12:11 AM
I bought this Proform ring filer several years ago, it makes gapping rings a lot easier and quicker 1 to 2 hours on the top moly rings depending on the application and how precise I wnat the gaps, 40 minutes to 1 hr. to do the softer 2nd iron rings, again depending on how close they end up being, .0010 requires some stoning on the last fittings and within .001 to .003 only needs the wheel on the girnder How many of you are checking the ring side clearances and back spacing? Oops, forgot the picture
Re: OK.............Let's see a show of hands. [Re: Cab_Burge] #997560
05/24/11 10:05 AM
05/24/11 10:05 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I don't know what is worse,, filing ring's or spiro-loc's.
Re: OK.............Let's see a show of hands. [Re: dartman366] #997561
05/24/11 11:07 PM
05/24/11 11:07 PM
Both
Re: OK.............Let's see a show of hands. [Re: dartman366] #997562
05/25/11 12:08 AM
05/25/11 12:08 AM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
I like doing both
