Quick question about a 340 K member A body - JohnRR?? #997443
05/22/11 12:54 PM
05/22/11 12:54 PM
mopar346 Offline OP
Let me tell ya about fat chicks!
mopar346  Offline OP
In the middle of a assembly and I begin to wonder what K I have in my GTS. It had a big block K (340 car) which went bye bye (I want get into that right now ) and bought a SB K. The question is, is there a difference in a 340 and a 318 K. Early style not a spool style. I know there is a diffence in mounting brackets and I have the correct 340 ones on a 360. As usual I have stopped working to find this out. Quick help apreciated.
Thanks in advance, Kevin
Careful, your character's showing!
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997444
05/22/11 12:57 PM
05/22/11 12:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No no difference . are you sure it's a small block and not a /6 ? Are you having an issue or just want to make sure ?
Re: Quick question about a 340 K member A body - JohnRR?? [Re: JohnRR] #997445
05/22/11 01:00 PM
05/22/11 01:00 PM
mopar346 Offline OP
mopar346  Offline OP
Currently no issue, making sure before I pull the K and mount the engine. The holes in the k mounts look inline and on the engine the driver's side appears back a little. I quess I'm not sure its a SB but doesn't the driver's perch on a /6 stick up at an awkward angle? Got picture of either handy?
Thanks by the way!
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997446
05/22/11 01:07 PM
05/22/11 01:07 PM
scratchnfotraction Offline
here is a pic of a sb v-8 on a /6 k frame
you can use the pass side sb truck engine bracket and an early style driver side car engine bracket
old hot rod trick when you have a /6 k frame
just in case you find its a /6 k frame and not a sb k frame
this will work so you dont have to locate another k frame
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997447
05/22/11 01:11 PM
05/22/11 01:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't have a picture handy and if no comes up with one I can look at a K later when I get home .
Re: Quick question about a 340 K member A body - JohnRR?? [Re: JohnRR] #997448
05/22/11 01:15 PM
05/22/11 01:15 PM
mopar346 Offline OP
mopar346  Offline OP
Thanks guys, I will get a picture of my K and post it for ID.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997449
05/22/11 01:26 PM
05/22/11 01:26 PM
mopar346 Offline OP
mopar346  Offline OP
here it is
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997450
05/22/11 01:45 PM
05/22/11 01:45 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
It's a small block, but with any k-member id questions go here:
http://www.engine-swaps.com/Pages/ProductsType/K-Frames.html
Re: Quick question about a 340 K member A body - JohnRR?? [Re: Jim_Lusk] #997451
05/22/11 01:53 PM
05/22/11 01:53 PM
mopar346 Offline OP
mopar346  Offline OP
Thank you, website info saved as well. Back to work I have to catch a plane in at 6 so not much time.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: Jim_Lusk] #997452
05/22/11 02:59 PM
05/22/11 02:59 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Thats a great link Jim... Thanks.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997453
05/22/11 05:38 PM
05/22/11 05:38 PM
mopar346 Offline OP
mopar346  Offline OP
K out, engine & tranny mounted, back in the engine bay. The K is slightly twisted to the engine as I suspected it would be. When the engine & tranny are running straight in the engine compartment and tunnel the driver's side is probably 3 inches behind the holes when the passenger's side is even. Any thoughts? I will respond back at the airport.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997454
05/22/11 05:53 PM
05/22/11 05:53 PM
are the engine brackets on the correct side of the block lugs?
Re: Quick question about a 340 K member A body - JohnRR?? [Re: scratchnfotraction] #997455
05/22/11 06:46 PM
05/22/11 06:46 PM
mopar346 Offline OP
mopar346  Offline OP
I believe so they are both behind the lugs, if the driver's were in front it would be pretty close but the machining of the block doesn't allow for a front mount, so I figured it was behind. I could modify the bracket but haven't chosen to yet. I figured I would ask first. I was out of time anyway for the day so I was at a stopping point. Thanks for the help though.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997456
05/22/11 06:49 PM
05/22/11 06:49 PM
mopar346 Offline OP
mopar346  Offline OP
In case I wasn't clear it is a 360 with 340 mounts and the above K with a 833 behind it.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997457
05/22/11 09:51 PM
05/22/11 09:51 PM
mopar346 Offline OP
mopar346  Offline OP
Operating on berry is it possible that I have e body brackets
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997458
05/22/11 10:12 PM
05/22/11 10:12 PM
I know useing the 318 bracket on a 360 you have to use some washers to take up some space with the block lugs.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: scratchnfotraction] #997459
05/22/11 10:38 PM
05/22/11 10:38 PM
mopar346 Offline OP
mopar346  Offline OP
Same with 340 mounts
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997460
05/23/11 12:04 AM
05/23/11 12:04 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
The holes in the A body engine mount brackets should orient the biscuit to the front of the bracket. If the holes are near the rear of bracket, they are B/E body brackets.
On the left is the A body driver side 340/360 mount
The 340 mounts require no washers or spacers of any kind on a production 360 block. 360 block drivers side mount ear spacing is the same as a 340.
Re: Quick question about a 340 K member A body - JohnRR?? [Re: RobX4406] #997461
05/23/11 12:42 AM
05/23/11 12:42 AM
mopar346 Offline OP
mopar346  Offline OP
Bingo thanks I knew something didn't look right time to buy new brackets
Re: Quick question about a 340 K member A body - JohnRR?? [Re: mopar346] #997462
05/24/11 12:22 AM
05/24/11 12:22 AM
mopar346 Offline OP
mopar346  Offline OP
Anybody know if I just need a driver's side or is the passenger's side different as well? Isn't the passenger's the same as a 318 A body?
