Quick question about a 340 K member A body - JohnRR??
#997443
05/22/11 12:54 PM
05/22/11 12:54 PM
Posts: 11,836 Florida
mopar346
Let me tell ya about fat chicks!
In the middle of a assembly and I begin to wonder what K I have in my GTS. It had a big block K (340 car) which went bye bye (I want get into that right now ) and bought a SB K. The question is, is there a difference in a 340 and a 318 K. Early style not a spool style. I know there is a diffence in mounting brackets and I have the correct 340 ones on a 360. As usual I have stopped working to find this out. Quick help apreciated. Thanks in advance, Kevin
Careful, your character's showing!
Re: Quick question about a 340 K member A body - JohnRR??
[Re: JohnRR]
#997445
05/22/11 01:00 PM
05/22/11 01:00 PM
mopar346
Currently no issue, making sure before I pull the K and mount the engine. The holes in the k mounts look inline and on the engine the driver's side appears back a little. I quess I'm not sure its a SB but doesn't the driver's perch on a /6 stick up at an awkward angle? Got picture of either handy?
Thanks by the way!
[Re: mopar346]
#997446
05/22/11 01:07 PM
05/22/11 01:07 PM
Posts: 15,487 Florida
scratchnfotraction
here is a pic of a sb v-8 on a /6 k frame
you can use the pass side sb truck engine bracket and an early style driver side car engine bracket
old hot rod trick when you have a /6 k frame
just in case you find its a /6 k frame and not a sb k frame
this will work so you dont have to locate another k frame
[Re: JohnRR]
#997448
05/22/11 01:15 PM
05/22/11 01:15 PM
mopar346
Thanks guys, I will get a picture of my K and post it for ID.
[Re: Jim_Lusk]
#997451
05/22/11 01:53 PM
05/22/11 01:53 PM
mopar346
Thank you, website info saved as well. Back to work I have to catch a plane in at 6 so not much time.
[Re: mopar346]
#997453
05/22/11 05:38 PM
05/22/11 05:38 PM
mopar346
K out, engine & tranny mounted, back in the engine bay. The K is slightly twisted to the engine as I suspected it would be. When the engine & tranny are running straight in the engine compartment and tunnel the driver's side is probably 3 inches behind the holes when the passenger's side is even. Any thoughts? I will respond back at the airport.
[Re: mopar346]
#997456
05/22/11 06:49 PM
05/22/11 06:49 PM
mopar346
In case I wasn't clear it is a 360 with 340 mounts and the above K with a 833 behind it.
[Re: mopar346]
#997457
05/22/11 09:51 PM
05/22/11 09:51 PM
mopar346
Operating on berry is it possible that I have e body brackets
[Re: mopar346]
#997460
05/23/11 12:04 AM
05/23/11 12:04 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
The holes in the A body engine mount brackets should orient the biscuit to the front of the bracket. If the holes are near the rear of bracket, they are B/E body brackets. On the left is the A body driver side 340/360 mount The 340 mounts require no washers or spacers of any kind on a production 360 block. 360 block drivers side mount ear spacing is the same as a 340.
[Re: RobX4406]
#997461
05/23/11 12:42 AM
05/23/11 12:42 AM
mopar346
Bingo thanks I knew something didn't look right time to buy new brackets
[Re: mopar346]
#997462
05/24/11 12:22 AM
05/24/11 12:22 AM
mopar346
Anybody know if I just need a driver's side or is the passenger's side different as well? Isn't the passenger's the same as a 318 A body?
