Six Pack E Body breather cap question #99715
08/04/08 05:00 PM
08/04/08 05:00 PM
Ohio
V
viperakron Offline OP
V
Ohio
Should the cap in the valve cover have two nipples? Do both the manifold breather hose and the the center carb vent line go to the cap?
Re: Six Pack E Body breather cap question [Re: viperakron] #99716
08/05/08 07:48 AM
08/05/08 07:48 AM
ive seen 3 nipple caps with one tube for the air cleaner, one for the carb fuel line vent and one for ???? (fuel line vent maybe?)
but 440 6 bbls have a vapor line that go to the return line.
so a 2 nipple cap seems like it would be right.
heres a bump for you anyways.
NO USEFUL INFO IN THIS REPLY
Re: Six Pack E Body breather cap question [Re: viperakron] #99717
08/05/08 09:22 AM
08/05/08 09:22 AM
East Bethel Mn
Danscudas Offline
Danscudas  Offline
East Bethel Mn
Depends on what year.
Re: Six Pack E Body breather cap question [Re: Danscudas] #99718
08/05/08 10:25 AM
08/05/08 10:25 AM
and?????????????
why be vague? give info!!!
Re: Six Pack E Body breather cap question [Re: viperakron] #99719
08/05/08 10:34 AM
08/05/08 10:34 AM
Turneffe
BJohnson Offline
BJohnson  Offline
Turneffe
1 or 3 (N95)or 1971 cars on V-8's. 2 with 6 cylinders.
Re: Six Pack E Body breather cap question [Re: BJohnson] #99720
08/05/08 10:45 AM
08/05/08 10:45 AM
Ohio
V
V
Ohio
Where is the vent on the center carb (1970) suppose to go? It looks like a hose should attach and go where?
Re: Six Pack E Body breather cap question [Re: viperakron] #99721
08/05/08 01:04 PM
08/05/08 01:04 PM
on a 3 nipple breather, theres a tube for it.
Re: Six Pack E Body breather cap question [Re: BJohnson] #99722
08/05/08 01:50 PM
08/05/08 01:50 PM
cataclysm80 Offline
cataclysm80  Offline
fuel vent just goes to open air unless you have N95 (cal emissions).
I didn't like that much, so I put a 2 nipple breather on my 6 pack so I'd have someplace to put the fuel vent, even though the 2 nipple is only correct for Cal 6 cylinders.
Tav
Re: Six Pack E Body breather cap question [Re: viperakron] #99723
08/05/08 06:05 PM
08/05/08 06:05 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
from what i know is
that in 70 on a n95 car (cal emission)
that it would have a 2 nipple cap with one line going to the tank and the other back to the air cleaner and the hose next to the throttle plate goes to the PVC on the left side VC
Re: Six Pack E Body breather cap question [Re: Day2Runner] #99724
08/05/08 06:11 PM
08/05/08 06:11 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
from what i know is
and on a 71 the 3rd hose from the breather cap goes to the port up by the metering plate( see circled) mines a 70 non 95 car
hope this helps
if im wrong someone please step in
so what do you got a 71 n95 car ??
if so you need a 3 nipple cap
70 n95 car will have 2
non n 95 will have one
Re: Six Pack E Body breather cap question [Re: Day2Runner] #99725
08/05/08 06:35 PM
08/05/08 06:35 PM
that port on the carb is the bowl vent.
So youre saying that on a 70, non cal emissions car, there will be only a single nipple breather and that goes to the air cleaner. So I guess the carbs fuel bowl vent is blocked (capped off) on those???
Re: Six Pack E Body breather cap question #99726
08/05/08 08:57 PM
08/05/08 08:57 PM
cataclysm80 Offline
cataclysm80  Offline
NO! You don't want to cap it off, it's a vent. It's just open to the air. I think a short hose goes on it just to help keep stuff out of there, but the hose doesn't go to anything, it's just open on the other end.
Tav
Re: Six Pack E Body breather cap question [Re: cataclysm80] #99727
08/05/08 10:42 PM
08/05/08 10:42 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
Here you go. This is an original untouched 440+6 1970 'Cuda. It has the California emissions and clearly the three nipple breather. The hose that appears to go nowhere actually goes to the shaker base plate. Hope this helps. Rob
1970 Hemi 'Cuda hard top clone
1971 Hemi 'Cuda Convertible clone
Re: Six Pack E Body breather cap question [Re: FJ6AAR] #99728
08/06/08 12:41 PM
08/06/08 12:41 PM
Frederiction. New Brunswick ,C...
RTshaker Offline
RTshaker  Offline
The picture showing the plumbing with the 3 nipples has a mix up in the hose connections. The bowl vent goes to breather , the opposite side PVc valve goes to the bottom of carb {these are switched in the photo} . Good picture though
Re: Six Pack E Body breather cap question [Re: RTshaker] #99729
08/06/08 12:57 PM
08/06/08 12:57 PM
cataclysm80 Offline
cataclysm80  Offline
someone swapped those two connections
Tav
Re: Six Pack E Body breather cap question [Re: cataclysm80] #99730
08/06/08 02:28 PM
08/06/08 02:28 PM
Mattituck NY.
FJ6AAR Offline
FJ6AAR  Offline
Mattituck NY.
Hi guys, I see what your saying (if your talking about my photo) and yes, it is very likely they were (obviously) switched. Thanks for the info. I will put them the correct way when the car is restored. Rob
